- Joined
- Mar 17, 2022
- Messages
- 190
- Likes
- 19
Heres a three way design using dayton drivers, front baffle has a 10 degree slant
Have tried smaller box 10x14x12 however without tweaking the crossover more, things are worseInteresting.
Aren't the cabinet dimensions of what looks to be WxHxD 10"x22"x16" a bit eccentric and impractical?
Edit: I mean they're basically narrower and deeper Wharfedale Lintons. Having tried a cardboard box model of the latter in my room to get a feel for their dimensions, my first reaction was not "if only they were narrower and deeper". Of course one data point and YMMV etc.
maybe you can nudge me in the direction of a few things to tryOn axis frequency response looks pretty good. But, the directivity is rough. You might look at using lower crossover frequencies for the midrange and tweeter, and working at getting them better phase aligned (the vertical directivity is showing phasing issues).
The software and file format are quite simple to use and driver data is readily available at parts express. Yes rounding off values is a must however also remember 10% parts maybe used and adjusted if measurements are offHow did you measure to import the frequency responses of the Dayton drivers to Boxsim and the max SPL ones?
For the crossover I would recommend to optimizing it to some E6/E12 capacitor and resistor series values which can be purchased, also for the coils you cannot vary inductivity and resistance separately, the values you got there from the optimizer are not realistic, so some rework needs to be done.
If it were me, that is not the driver combination I would use. I would use a midrange/tweeter combination that provides a more consistant horizontal directivity. That midrange is running into some issues above 1.5kHz. But, that is where the tweeter's resonant frequency is, and I probably would not push the tweeter that low. That midrange probably would be best suited for a waveguided tweeter you can crossover around 1.5kHz-1.6kHz.maybe you can nudge me in the direction of a few things to try
Thanks for the nudge, will also explore other midrange and tweeter possibilities that can also plug in into the boxes.If it were me, that is not the driver combination I would use. I would use a midrange/tweeter combination that provides a more consistant horizontal directivity. That midrange is running into some issues above 1.5kHz. But, that is where the tweeter's resonant frequency is, and I probably would not push the tweeter that low. That midrange probably would be best suited for a waveguided tweeter you can crossover around 1.5kHz-1.6kHz.
But, if you already have the drivers, I would try to get the drivers' phases aligned as best as you can. Sometimes I will sacrifice a little bit of the on-axis frequency response to do so if it makes sense. You could try using an impedance compensation network on the tweeter. Basically it is a resistor in series with a capacitor, then you put those in parallel with the inductor of the tweeter filter. If that has a positive impact, then you will need to adjust the values of the capacitor and inductor in the filter based on the new impedance of the tweeter and impedance compensation network.
Also, put in the actual DC resistance of inductors you will be using.
I am assuming that your simulation program also can predict phase and group delay of the individual drivers. If not, I would try modeling the speaker in VituixCAD.
www.audiosciencereview.com
I checked exemplary for one and it has only 0, 15, 30 and 45° measurements which is not enough for a good simulation?The software and file format are quite simple to use and driver data is readily available at parts express.
As I wrote before also please don't ignore the real ohmic resistance of the coils which can make a significant difference, I would recommend you to re-simulate it with Visaton ones with similar inductivity which are already included in the software.Yes rounding off values is a must however also remember 10% parts maybe used and adjusted if measurements are off
... and driver data is readily available at parts express....
I have a feeling what you are seeing is due to using traced data, if I am correct in my post above. But what do you see in post #1 that makes you think this? I am not familiar with Boxsim and without seeing the individual driver measurements or crossover points I didn't look carefully....That midrange is running into some issues above 1.5kHz....That midrange probably would be best suited for a waveguided tweeter you can crossover around 1.5kHz-1.6kHz.
I looked at the specification sheets on the Dayton Audio website: https://www.daytonaudio.com/images/resources/295-352--rs100-8-spec-sheet.pdfI have a feeling what you are seeing is due to using traced data,
Ah, that makes sense. I just didn't see anything in post #1 that clearly showed that.I looked at the specification sheets on the Dayton Audio website:
A few questions:Heres a three way design using dayton drivers, front baffle has a 10 degree slant
A few questions:
How did you simulate the "front baffle has a 10 degree slant"?
