I'm not sure there is a problem with any of your speakers. The pink vs. blue picture may very well be due to mic position. Did you measure the two from exactly the same mic position? If not, the difference you show is likely just the measurement, not the speaker.
Also, REW's capture button is your friend, and our friend too.
It's hard to compare directly photographs of your monitor, and saves taking pictures with phone and then uploading. And some of the angles are so tilted I can't read the legends or make a comparison.
For potentially damaged speakers, I measure impedance vs. frequency. You may not have the ability to do this easily (Dayton DATS is an easy way to do that).
You can also use an multimeter to measure the DC resistance, to see if there is a burnt driver or crossover component. Not as useful as an impedance sweep, but can catch some driver and crossover fails.
But I am not sure you have a blown speaker, am hopeful it is just changing mic position, so please confirm that part.
