3.1 Home Theater for € 1500
Anto102
Hi all! I'm looking for some ideas for 3.1 home theater setup for my new apartment, which is still under construction, so there's no problem to put an extra hole here and there (but no room for 5.1 setup), even if i'm considering buying a Sony Theatre Bar 9 Sound bar (i know it's not the same as real audio setup), because it requires no extra work (and it'll cost me € 500).
As for the the left and right speaker, i'd prefer something to be attached on the wall. The center channel can also be bought later, just to have some to room with the budget in first place.
The Tv will be a 65" LG G4.
Room map attached: the yellow one is the couch, the blue one the tv.
You say there's no problem with putting a hole here and there. I'm assuming the answer is no since you said it's an apartment, but are in-wall speakers an option? They're generally better than anything you'd hang on the wall, unless maybe you're talking about using a wall-mount to hold up an actual speaker maybe?
You said you were considering the Sony sound bar for 500 euros. Is that your budget for the speaker pair?
Edit: Whoops I seem to have missed the 1500 Euro target from your thread title. My mistake. Assuming you do want to stick with an on-wall option, the Kef Q4-meta seem to be a good option.
I would prefer on-walls, in-walls are a bit too invasive, especially if one day for any reason I decide to remove them.
Consider that i'm based in Italy, so prices may differ.
Also, i'll need a source (maybe a Denon?)
