2nd generation EIGENTAKT PURIFI 1ET6525SA (successor to the 1ET400A)
I could well imagine that the successor to the NAD M33 will have these new modules. T+A will also be introducing a new AIO device with purifi in the near future. May be with these new modules.
Yet even this amp is not listed on the Purify site yet. No mention of it at all, no datasheets, just nothing!
To be fair, they're website has never been known to be updated in a speedy manner. When the 7040 rolled out it took a while to find it on the site.
Where can you see this?
The Model 10 powerplant is newly engineered. In partnership with Purifi, Marantz developed a new amplifier, two of which are used to achieve dual-mono operation. It operates as a fully balanced amplifier from input to output, with individual power supplies for each amplifier channel and all line-level input circuitry powered by a separate linear power supply unit. Distortion is astonishingly low – 0.05% THD across the entire audio band at full power and an order of magnitude better at half-rated power – while up to 30A of peak current means exceptional dynamic range, plus frequency response that is immune to load impedance.
JSmith
The technical data points more to the 1ET6525SA.
Nope. Data points to a power supply limited 1ET9040BA.
250/500 W and 30 A corresponds to a 1ET9040BA mated to an excellent power supply with rails at around +/- 24 V.
