27mm 4ohm speaker recommendation
Curupira
Somewhere inside a Brazilian jungle
Hello all,
I have a Harman Kardon Esquire mini portable Bluetooth speaker with both speakers showing signs of crackling and severe distortion. I disassembled the unit and took out the two 27mm speakers, 4ohm rated. There were no model or serial numbers on them, and given that there are several complaints on the Esquire Mini speakers failing, I don't want to get original replacements.
I'm looking for OEM replacements on Chinese marketplaces like Aliexpress. There are multiple brands like Ayima and GXSpeakers that I recognize from other lines and projects, but before committing to a blind buy, I wanted to see if anyone here has tried some of them and can recommend a link or unit in particular.
I'm not striving for high fidelity or any miracles from a 27mm speaker, just a reasonable performance.
Thank you all!
