2019 CES Asia ---SMSL will bring new product there
The M400 will be released next month, and the M200 will be released this month.
This is the design of M400, made by the Ak4499.
That is pretty! I had a M500 but that had issues with bad SPDIF connections. My OLED TV's SPDIF made the sound drop out every so often on the M500, will this have a different receiver or options to adjust jitter reduction?
Considering it is AKM, I hope there is a good pop-noise circuit for when sample rate or input changes. Other manufacturers often have some problems with this!
You can try to change another cable
Some data of M400 in the laboratory, and very stable, can be used with MQA.
Those THD+N graph and SINAD numbers look very impressive.
distortion looks very nice~ will it output 5V balanced then? or is that just for testing
I think its the max output values there. In any case, the homogenized testing voltage for balanced out is 4V, so SINAD numbers should be a little bit lower at that value.
Nice! I'm curious about the price of the m200 and if it will fit the size of the sp200.
@SMSL-Mandy
Neat! But I can't spot the headphone input in m400. I was 100% sure the previous designs had it....
Doesn't look like it has one. Pre-amp/digital volume and DAC, comparable to Topping D90(MQA).
See:
Reactions: Tks
I think they redesigned the features, to include MQA decoding (at a cost).
Yes, I think marketing made some juggling there probably reasonable from their point of view. Sad for me but otherwise it would be a direct competitor and most likely better device than m500.
So no Ak4499 combo so far...
Maybe it was inferior chip and head-amp before. AK4499 and no head-amp now. And MQA to compete with D90.
There is something wrong with headphone outputs regarding this photo. AFAIK, M400 does not have any amplifier, nor does it have a Bluetooth input. Can you enlighten us @SMSL-Mandy ?
Sp400 will be resealed in June. Suit with the M400. And M400 is a pure DAC.
