Your installer might actually believe all the audiophile snake oil nonsense.... could be well intentioned. Could be....( the fact that he pushed me towards cables and power conditioning isn’t helping )
ding ding dingYour installer might actually believe all the audiophile snake oil nonsense.... could be well intentioned. Could be....
Bling is the absolute norm for Saudis, looking at it from their angle I would consider the choices there as the bare minimum.ding ding ding
Really? Can you recommend a company who does custom subs with custom wood finishes? Thank you in advanceFor 10k, you could have two custom subs built to order with whatever wood finish you like.
Subwoofers are difficult to measure, so opinions are quite varied and they are just that, opinions.Somewhat perplexed regarding the negative vibes on Rel’s, especially the 212’s I am attracted to, I have been reading reviews and both HT centric websites as well as magazines like the absolute sound have nothing to say but positives, these particular subs score 9+ out of 10 on every website I came across and seem to be recommended for both action movie impact as well as subtle musical notes.
Not doubting the opinions of anyone but a bit confused as to why such stark opinions….
Did you ever read a negative review on anything in any of these magazines or websites? Are the scores almost always correlated with price?websites as well as magazines like the absolute sound have nothing to say but positives, these particular subs score 9+ out of 10 on every website I came across and seem to be recommended for both action movie impact as well as subtle musical notes.
No, but any decent carpenter can make you the needed box in whatever design you like. Selection of amps and drivers should not be an issue. And as long as the internal volume is kept and the thing is build like a tank, you should get an absolute monster of a sub! For a room like this, closed sub would be the way to go. That makes things a whole lot simpler.Really? Can you recommend a company who does custom subs with custom wood finishes? Thank you in advance
Most probably they will be. They are not bad subs, and the expense ones will probably be excellent. But they are not very good value.Your RELs will be fine. That's not the place to focus. Your in room response and DSP are much more critical.
I'll respond by direct message.Thanks for your honest thoughts. I am tortured as I write this, on one hand the visual aspect has been extremely excited, on the other I certainly don’t want to spend 10k on 2 subs that underperform
If I could take a moment of your time...
As you are new here, you are not perhaps aware of the ASR culture and approach to audio. Objective Measurements (hence the science in ASR...) rule, and typical subjective audio terminology is secondary at best, rejected outright at worst. Other forums will have lengthy discussions on the sonic differences between power cords, which is pure BS. To Rel and how that applies, you're paying mostly for looks, name, (no longer relevant) high level connection, etc, vs objective measured reasons to drop that much $ on a sub. Various brands offer as good, maybe better, performance for substantially less $. Bottom line is, REL is viewed as very poor value.Somewhat perplexed regarding the negative vibes on Rel’s, especially the 212’s I am attracted to, I have been reading reviews and both HT centric websites as well as magazines like the absolute sound have nothing to say but positives, these particular subs score 9+ out of 10 on every website I came across and seem to be recommended for both action movie impact as well as subtle musical notes.
Did I miss the room dimensions?Thank you for the advice. Would it be better to switch to 2 15 inch subs or 4 10 inches or 4 15 inches?
