1More USB-C Headphone Adapter Review
Rate this headphone adapter:
    Votes: 61 55.5%
    Votes: 37 33.6%
    Votes: 10 9.1%
    Votes: 2 1.8%
This is a review and detailed measurements of teh 1More USB-C DAC and Headphone Adapter based on CX31993 IC. It is on kind loan from a member and is included in the 1MORE Penta Driver IEM.
This dongle looks like any other except that it didn't come with an adapter for USB-A host connection. It has a major problem though: the headphone socket is too loose barely making a connection. I barely got it working for this test. Whether they are all like this, I don't know.
1More USB-C Adapter Measurements
I was saddened to see that the output maxed out at just 1 volt instead of 2:
Combined noise and distortion is very good however for a dongle with distortion at threshold of audibility. Dynamic range is also very good at full volume:
But as you see, it is quite poor when the Windows volume was adjusted for nominal 50 millivolts:
It seems to have high residual noise which could be system dependent.
Jitter had a lot of random noise impacting the clock which may be related to above:
You can tell that from the wide "skirt" of the noise spectrum.
Output power is of course limited especially at 300 ohm:
I guess performance is what you expect for a "free" headphone dongle. Still, more could be done to optimize performance without a cost hit. The gain for example, is too low as both the 32 and 300 ohm measurements show no clipping. The fact that the headphone jack is broken doesn't inspire confidence as far as quality.
I can't recommend the 1MORE USB-C Dongle/Headphone Adapter.
I wonder how this compares to Apple, Samsung or Meizu dongles, as it was not clear from the graphs provided.
Decide if your headphones are low or high impedance and then look in the ranking graphs in the review. The higher the better.
And here, I thought, an adapter was just running wires from here to there and not doing anything else.
The headphone socket is solid on the Subynanal USB-C dongle DAC I bought on Amazon for $3. At the moment it's $6. It has a Realtek ALC5686 chipset.
I used a generic CX31993 dongle with DD and DD+BA IEMs and never heard a noise floor.
I suspect this is a worse implementation than whatever version you got, then.
The DUT has roughly the same noise floor as my Schiit Valhalla 2 and it's certainly noticeable there with my IEMs. I believe mine are less sensitive than the 1More Penta that this dongle comes with, so i'd be shocked if the combo didn't have an audible noise floor in a quiet room.
Anyone have a pair to confirm? (possibly @amirm could check?)
I don't understand how the socket can be loose. Surely these are generic parts, made to spec by the thousand (or more)?
I use a usb-c dongle to aux to tape deck adapter in my 1999 Lexus. Noise noise every where, but I can still enjoy the music :) Dam Lexus and it's electronics will last forever.
I'm going to get the apple dongle for my Samsung phone.
The SINAD seems to drop more dramatically than expected with the volume adjusted to 50 mV out, I'd expect closer to 80-85 SINAD than 60 for CX31993 based on user measurements. Although here Amir chose a 600Ohm load which is a strange choice for a 1V dongle frankly. I can't rule out that this is how it performs under the given conditions. Unless in Amirs testing the volume was erroneously controlled in software instead of hardware, which would expectedly nerf the metrics, not reflective of real-world performance in that case.
With these integrated SoC (USB bridge, DAC, Amp, ADC, charge pump), there is not much to “implement”. For a given chip, differences should be minimal…
Just got a new Motorola phone. Only USB-C, no 3,5mm ... if I wanted to enjoy some good sound, is it still the Apple dongle (does it work on an Android?) or anything else I should keep looking for?
