1More Sonoflow NC Headphone Review
Rate this headphone:
    Votes: 17 8.8%
    Votes: 36 18.7%
    Votes: 95 49.2%
    Votes: 45 23.3%
FYI: Bought in April 2023. Died in October 2025 after light use. Won't turn on anymore.
Had a similar issue and turned out it wasn't charging. Mine was fixed with a different cable. FWIW FYI
I was able to fix it. Put the 2.5mm jack into it and removed it again. Now it's turning on again. Must be some reset function.
My issue was with the triple driver. Don't know but the 1More people are very responsive. Try them. Good Luck :)
Super.;)
What I noticed with the Sonoflow Pro is that the workmanship isn't that great. Sure, it's made of plastic like even the expensive Sony or Bose models, but you can hear it crunching when you put a little more strain on the headphone brackets or move the ear cups.
The Q30 from Soundcore is better in this regard, although overall it seems ricketier than the Sonoflow Pro, but it doesn't crunch. But maybe I also caught a Monday model.
I got the Sonoflow Pro so I could use the LDAC codec. And yes, it really does make a difference compared to the Soundcore Q30. In the developer settings of my smartphone I set the LDAC codec to the best sound setting of 990 kbps. And it's sounds amazing with Tidal flac streaming. Significantly better than the Soundcore Q30 with AAC for the same Tidal Flac songs.
I didn't have the Sonoflow Pro's predecessor, so I don't know if the sound is better or not. In any case, I am very satisfied with the Sonoflow Pro and can only recommend it.
Folks, update: My Sonoflow Pro bought last year from amazon broke (manufacturing date 24/08). A piece of plastic has broken off the locking mechanism of the right earcup. The 1more support over amazon chat was pretty good. They send me a replacement without sending the broken headphones back. After 3 days I got the new sealed replacement. The replacement has manufacturing date 25/05. The blue headphones came no more with a blue case but with a black one now. And in comparison to my older broken Sonoflow Pro the new replacement has a much much better workmanship. It's now tighter, no more crackling and creaks, has a much more premium feeling than the one from 2024 though it's still made of plastic. And as I'm a courious guy I weighed both models. And you know what: The new replacement model from 2025 weighs 10 grams less than the model from 2024. So it seems that 1more has rebuild the Sonoflow Pro in 2025. Now I'm curious to see if the new model lasts longer.
Technically, they both sound the same. That means thousand times better than the crappy sound of the Sony WH1000XM6.
I bought a pair of Sonoflow Pro HQ51 off Amazon. It has the LDAC logo on the packaging. I have tried three devices, Windows 11 alternative A2DP driver, Pixel 7 Pro and Samsung Tab A9+, none of them show LDAC support, only AAC/SBC on Pixel 7 Pro and only SBC in Win11, and nothing on Samsung tab. All three shows LDAC support for my Shure Aonic 50.
OMG! People! What's wrong with you all??? Based upon all positive reviews here and there I bought both versions of SonoFlow (Old and new "PRO") and both are absolute garbage. Worst sound ever! Period. Mushy, bassy, boomy, resonant shit without detail, definition, highs,... Horrible. No EQ is able to fix the sound.
I thought that this was a serious website. I'll give them to the first homeless person to keep his ears warm in winter.
Maybe it has been changed since the original review. The pair I heard sounded pretty good and I'm not one for Bluetooth headphones. But the one I listened to i bought over a year ago.
Yeah ok then lol
They sound excellent to me. You aren't listening to them wired by any chance are you?
Yeah ok then lol
Excellent? Lol. I must be from another planet.
I sacrificed myself for you and tried a wired connection. And guess what? It was even worse. Much worse. Plus, I don't understand why you would buy BT headphones and then connect them with a wire. ??????? I have many wired headphones at home and they sound average, but always 1000% better than this junk. Apparently, I ruined my hearing on professional studio monitors from Focal and Dynaudio and headphones from AKG and Sennheiser and on my home Top HiFi from Denon 2000 series, Dynaudio Confidence, Wharfedale, and others... And that's why I can't appreciate this Chinese luxury for $70. :facepalm::D
Lol. I asked about the wired connection because that’s known to provide WORSE sq on the phones, not as a suggested improvement! Thought it might explain what you were hearing. How bout you drop the ‘tude bro and relax? Sorry you don’t like the sound but i think they sound very good and they also have pretty solid measured performance so I don't know what to tell you. Shrug. I have a damn nice headphone setup of my own and no, the Sonoflows don’t sound as good…but for $90 cdn for an ANC bluetooth setup they sound pretty damn good.
Maybe you damaged your hearing by listening to all that high quality NON-Chinese gear too loud! :D
I don't care about the price, only the sound. If there was great sound for under $100, that would be great, but there isn't. Period. I just hate lies.
I might as well take dog poop, measure it, wrap it in gold foil, and then say that the measurements came out great. And that it's a full 9 inches and that it's great Swiss chocolate.
whatever man. Sounds like you came into the situation with your mind made up and then heard exactly what you wanted to hear.
I don't know. Maybe you got a dud pair. But, if the sound is what you say it is, why wouldn't the measurements show it? Mushy, boomy, bassy resonant shit? Why would that not show in the measurements just like the difference between wired and non-wired clearly shows up in the measurements? What magic is it that your golden ears are hearing that doesn't show up in the measured performance of the headphones?
I wrote that I bought both models. The original SonoFlow and then the new SonoFlow PRO. And I went into it thinking that for a few dollars I would get great sound for traveling. Headphones that I wouldn't have to worry about if they got damaged or lost. And I got junk. Period. Both models are total junk. And I emphasize that I bought them directly from the 1MORE e-shop and they were brand new.
There's no magic happening in my ears. I just know how to distinguish good sound and naturalness from terrible noise.
Thanks to this experience, I am leaving the "scientific" forums that believe in graphs as if they were the Bible, and I am returning to the simple principle of listening.
Graphs obviously don't always reveal everything. Often, you can find practically identical graphs, yet the sound is diametrically different. Reality is obviously more complex.
you do you.
But I'll ask again, if you are hearing big boomy mushy bass...why would that not display quite clearly in measured response? Pretty much every little difference in sounds shows up in a simple frequency response chart. You change a slider on an EQ and you can see the change easily in measurements...even tiny changes you wouldn't note by ear.
Yes, often people hear differences in things that measure the same. Cognitive bias is a real thing. Hence a market for rca cables costing hundreds of dollars.
Don't worry about me. I'm really not the type to be swayed by prejudice, marketing, high prices, and the like.
I don't care about it at all, whether it's audio, politics, food, or drink. Just nothing. People who buy audio woodo jewelry for thousands of dollars are idiots to me. I only care about real and tangible value. I can appreciate mashed potatoes for $1 if they're great, and I can pour $100 wine down the toilet if it's disgusting. I'm a very specific person.
1more is not answering my email. Why am I not seeing LDAC support on three different devices?
