- Joined
- Apr 24, 2019
- Messages
- 1,501
- Likes
- 2,847
https://www.diyaudio.com/forums/equ...rtion-audio-range-oscillator-post5936075.html
Yes, I used an external PS as Jan did.
"auto-tracking active notch" ?https://www.diyaudio.com/forums/equ...rtion-audio-range-oscillator-post5936075.html
Doh!Yes that one is photo-resistor based, Victor's is FET based. That article references the one we did in 1994 which was Blackmer VCA based.
I quoted Jan's measurements of Victor's oscillator above which added nothing to the floor of his AP.
Sorry for the noise...Very interested: https://viccc42.wixsite.com/uld-audio
Maybe beats AP !?
Thanks! I'm using the first gen RME Babyface (Silver Edition), had it since 2011.Nice stuff! Which sound card do you use and which software?
Looks cute.
I designed and built a 5V in Micro USB to 35V out galvanically isolated boost converter to use with these oscillators. I am not exactly happy with the performance and I'm not sure it can live right next to the oscillator in the same box yet without showing up in the spectrum. If I get more time to work on it and can improve the performance I will post the files.
I wish there were a composite / buffered version that could drive more demanding loads without much distortion increase.
I had a look to your page before purchasing Victor's 1kHz oscillator.Accidentally came by this thread now. I have a similar 1KHz oscillator from Victor, I've created a small PCB with 5V input to power it.
I've posted this a couple of years ago on my blog here:
http://tolisdiy.com/2019/03/11/low-thd-oscillator-power-supply-and-pcbs-as-case-panels/
If this is of use to anyone, feel free to use/modify as you see fit. The Gerbers are available for download at the end of that page as well.
The measurements shown on that page are when its feeding an EMU 0404 USB directly, so I would not use these as the oscillator performance, but rather a measure of the EMU itself.I had a look to your page before purchasing Victor's 1kHz oscillator.
I feed mine with a set of 9V cells.
Distortion is pretty low, but noise is higher, in my case.
Hi,I got one of these recently - really happy with the performance! Most definitely a huge overkill for my hobbyist needs, though - but a fun project nevertheless.
Anyway, I'm powering mine from an isolated multi-output guitar pedal power supply, connecting 4 x 9V outputs in series and using series resistors to get the voltage down to the required 35V. Didn't get the matching Twin-T from Victor sadly, so I decided to build one myself.
Here's some photos and measurements.
Oscillator board I received from Victor:
Inside the Twin-T notch + final devices built into boxes and with labels printed:
Have to say it was a bit tedious to match the Twin-T notch filter components to get a nice, deep notch- especially for balanced use!
As far as measurements go, I first recorded the notch frequency response, so I could use it as a calibration curve in REW to compensate for the filter response:
Here's zoomed to the 1kHz area, to better see the filter depth:
As you can see, the channels are not perfectly identical, but still fairly close and good enough for me
And this is the oscillator performance when running through the notch filter (with notch calibration curve applied in REW, 1M-point spectrum using Blackman-Harris 7 window and 32 averages)
Basically the distortion components are ~160dB down from the fundamental and buried in the noise floor.
I'm using the oscillator mainly to try and isolate the distortion components of my soundcard ADC from those generated by any device I'm measuring - since I don't really have calibrated equipment, this was a nice and not too expensive way to get some point of reference.
