18Sound10NMB420 closed box?
Ema79
Good morning, I should start building my speakers soon. But since I had second thoughts about a 12-inch driver, I switched to a 10-ohm one, but I can't find many products suitable for a sealed box project. Or at least not with professional components.
My speakers will be tri-amped with a Xilica DSP.
For bass, I have power with an IcePower 1200AS2.
But now I'm having trouble calculating how to get a good enclosure. I'd like something permanent that I won't have to mess with again, so I'd rather not make a mistake.
The driver I chose is this one: https://loudspeakerdatabase.com/18Sound/10NMB420_16Ω
I'd go with a 16-ohm one as it's more suitable than the 8-ohm one.
With the simulation with WinLSD, I get a very low volume, about 10 liters, for a leveling of about 0.707.
A good compromise between response and volume would be about 30 liters.
Which would be the same volume as the VAS. With a QTC of about 0.470.
And here I can't go any further because I don't have the expertise to determine whether it's incorrect loading or not.
Could you help me find a good compromise for this driver?
Or would it be better to choose another driver? If I had to choose another, could you recommend a driver suitable for frequencies from 60 to 250 Hz,
with a max MMS of 34 grams and an Xmax of 4/5 mm with a demodulating ring? Thanks everyone for the replies.
WinISD should tell you everything you need to know (more than we can tell you without running the simulation/modeling ourselves), and it should help you decide on a sealed or ported enclosure and help you make any other compromises that are best for you.
It's very common to put a subwoofer in a "small" sealed box and then extend the bass with EQ (DSP or analog) and "extra power". It's a bit easier if you are manufacturer and you can make a custom equalization circuit but there are plate amplifiers with adjustable EQ. I assume some "small" full-range active monitors also have EQ built-in (for other reasons too).
This post is a generalization of the difference between sealed and ported speakers. (WinISD should show you the same thing.) The ported speaker goes lower before before it starts falling-off but it has a steeper slope so at some point the sealed speaker is putting-out more sound. You can also "tune" a ported speaker with a small bump-up, which will extend the cutoff frequency down a but more. And the bump may be unnoticeable or desirable.
Sealed speakers are "better" if you're going to boost with EQ because the ported speaker will just flop-around with boosted low frequencies while not putting-out much sound.
10-inches?
That seems kind-of small (to me) for all that massive power you have. ;) (But with 16-Ohms you won't get "full power".) WinISD is probably showing you that with a small box, a smaller woofer usually works better. So if you limited in cabinet size a smaller woofer may work better. But you really have to plug-in the Thiele-Small parameters to know for sure.
At home, I have speakers with two 6.2-inch drivers per speaker, which should equal an 8.5-inch driver. In terms of sound pressure, I have nothing to complain about. What I'm looking for is a driver that can run at full power at 70Hz, because I also have an 18-inch subwoofer that goes linearly down to 15Hz.
I have an Xilica XP 8080 DSP, so I can adjust the volume at certain frequencies. For mid-bass, I'll have an Eighteen Sound 6ND430, which will assist the 10-inch driver if necessary. I chose a 10-inch driver only because I read somewhere that going beyond that size results in a loss of precision and focus in the low-frequency response.
But if that's not the case, I might consider a 12-inch driver.
Since it will be 3-way loudspeaker, 10NMB420 will be an excellent midrange driver in 12-15 liters closed box, covering frequencies from 150 Hz to 2 kHz (3 kHz peak needs notch filter).
In general, professional 10" drives can't reach 60 Hz in closed box.
Realistically, with DSP, the only requirement for your woofer is low fs, large Xmax and high power handling. The rest you can straighten out digitally. I think on DIYaudio there is a long thread with distortion tests of 10” PA woofers. Might be interesting to look at.
How about FaitalPro 10FE300?
Thanks. After searching around a bit, I found this driver with a demodulation ring. It's a 12-inch unit. It seems to be of excellent quality. But I don't have the necessary expertise to understand it. Is it a good alternative? Thanks to everyone for your patience.
https://loudspeakerdatabase.com/SICA/12PF3
That's a 12" woofer, though ;) But Sica makes really nice drivers. I'm eyeing the 10S3CP myself. There is even a 4R version.
Also, Beyma, has some monsters, like 10MC700Nd, or 10MCS500. The MC7000 has a smoother response.
