That's an opinion based entirely on your personal preferences, isn't it?For home use there’s no need to do that.
For me, no, I'll not get sufficient output out of smaller closed boxes.You’ll get plenty of output out of a smaller closed box, which offers the additional benefits of pressurizing the room lower and avoiding vent resonances.
And I need to be added to the list of folks who say vent resonances are a non-issue, if a sub is being used as a sub and crossed sufficiently low. (120Hz 4th order etc.)
I fully agree large signal performance is what counts. But are you aware how far small signal simulation has come in predicting large signal performance?Basically small signal modeling is pointless today. All you really need to concern yourself with is power and excursion. EQ will set the frequency response.
Have you used Hornresp for subs? Excursion and power are modeled quite well imo. I've done a fair amount of large signal sub testing outdoors and have found good correlation with Hornresp.
Won't that strategy apply clipped waves to the sub?A good rule of thumb if you don’t want to get into setting limiters is: enter the driver and your amp power (or the biggest amp you might use) into Unibox or whatever, and find the smallest closed box that will push the driver to rated xmax.
That is, unless you have a clip limiter built into the amp (which unfortunately, most home gear does not, afaict)
I'm happy setting limiters, I want all the transient head that is available! Heck, I've even built frequency dependent limiters in programable DSPs to get every clean mm excursion.
I agree, subs are easy. Easiest DIY of all.Subs are easy, especially when you’re dealing with this kind of extreme driver.
For reference, I recently had to replace an Aurasound NS18 that started to make some noise after ~15 years of service in three different cabinets (pour out a glass). I used a BMS driver in the I think ~85L closed box, though I think 850 not 862. After EQ there’s no difference I can detect. (The other 2 subs use Aurasound drivers.) The system still extends down to 16Hz with a smooth rolloff below that. It is still smooth to ~700Hz, well beyond
You use a sub up to 700Hz?
Yikes, I never cross higher than 120Hz, and i use a 16th order low pass. (linear phase)
Glad you're happy with the amount of subs and extension you have...
I could still use a little more of each.....and I'm running four of the 862's (ported)
Back to personal preferences
