As I said - no harm from 2 sets of side surrounds. But as you move from front/side to back, we just don't hear the sounds so clearly from that angle. Our ears are not made that way. If I had to drop a set of speakers from my larger HT, they would be the back surrounds. They definitely contribute to the overall resolution, but not nearly as other speakers in the system.Thanks. I'll look into WaveForming and its requirements.
By the way, 2 sets of surrounds even with 1 seat or 1 row of seats will help in the panning of Atmos objects, no? Atmos objects (at least with well designed Atmos mixes) use as many speakers as you have available. So, even with 1 seat and many speakers surrounding the seat will provide more "spatial resolution" with well designed Atmos mixes. At least that is my reasoning for have a high channel count.
Best thing about Trinnov is its mic and raw data it gets that appears to be in excess of what other AVPs can get. But for your particular room, I actually think ART would do better. Do some reading on what ART does. It is a unique concept that works based on virtual channels and collaboration of all speakers engaged in support (you chose the pattern). It uses UMIC or similar mics, so probably not as good as Optimizer above ART range, but it you don't sort out the bass, it might be of little consequence as what you will likely hear above that as it will be muddied and concealed.
