Svend P
Or just not enough processing power?Folded under no pressure and had to ask AI for help.
Peak brainrot.
Peak brainrot.
I returned mine. The firmware has too many issues. Also the softness you refer to may be a poor clock implementation. It never sounded close to neutral to me either. Overall I loved the Luxsin X9 much more.I received the D900 today, and I can say with confidence that it has not excited me as much as the D90III Discrete. The D900 certainly sounds better in many ways, but the overall sound setup is similar to an EQ being on, despite the fact that PEQ is off. The D90III sounds more neutral, clear and distinct. The D900 sounds soft, too soft, like through cotton wool. And with PEQ on, the sound can be improved a little, but it still lacks neutrality. I suppose there is some confusion with PEQ... And there is another flaw, when you turn it off, the D900 loses all settings.
The D900 needs a major SW update!
Not true. The D900 has 32 bit resolution while D90 3 has 16. It is more resolving because it has more processing digital power.
It has much more processing power as it uses 32 bit resolution as opposed to 16 for the D90 3
Not true. Professional studio gear always processes in 32 bits. It is very technical but the added bits of information are less likely to compromise the original signal as processing is done in extended bit mode. Also, it helps with shaping and digital filtering.
This way you can better filter without loss of frequency extension and still provide more gradual filtering to eliminate the ringing effect. That is why those that had the D90 III Discrete report that the D900 has much more detail and at the same time is not as harsh sounding.
Interesting, but... how is this audible?
What I have learned is that their programmers are not the best. They fix some things and create many other issues. They are not in the same league as the programmers from Eversolo or Luxsin. The later are in a completely different zone.So PEQ is broken here as well...on a $1,800 DAC.
It was easier to excuse bugs with the DX5 II, a $300 DAC/amp. I wonder what the excuse will be this time.
Topping fixed DX5 II issues quickly partly because vigilant ASR members reported problems and because plenty of units were sold. At $1,800, far fewer people will own this DAC, let alone beta-test it.
From the kitchen, I presume?PS: my wife, who has very good hearing, tested the D90 and D900 on quality piano music, said that the D90III Discrete sounds much better, clearer and more natural than the 900. The D900 sounds muddy in the middle.
My wife is a Hardware Engineer, I am also an Electronic Technician and we have been involved in music for many years. So keep your jokes to yourself.From the kitchen, I presume?
Then please explain from an engineering perspective how there can be a difference in sound if they measure identical?My wife is a Hardware Engineer, I am also an Electronic Technician and we have been involved in music for many years. So keep your jokes to yourself.
Since the following should be well within your reach and technical capabilities....My wife is a Hardware Engineer, I am also an Electronic Technician and we have been involved in music for many years.
