mbd-00
- Joined
- Jun 25, 2026
- Messages
- 12
- Likes
- 27
Hey all - I've been actively building a web based enclosure simulation tool which I launched in Jan this year.
What started as frustration with WinISD is now starting to innovate in other areas.
It's got all the bits you'd expect from WinISD - Vented/BR/PR/BP4/BP6, graphs, classic/TL simulation, end correction - so instead I'll talk about what's different:
- Modular dashboards - Dashboards are composed together of a series of tiles - so you can re-arrange, resize and create the dashboard you want for a given project
- Public accounts - share designs with community
- Cloud workspaces - save and run anywhere. Guest mode fully supported still
- Link sharing - publish designs and share with the community - e.g https://simulator.00aud.io/app/share/6NDL38-30L-bandpass6-cmq6hroqw0001js04267neihw
- Headroom simulation - simulate headroom and amplifier requirements. Think of this as a more granular way to understand max acoustic output - whether your design is constrained by port velocity, average power or excursion
- Lots more custom tiles - Baffle step, compare X-Y (e.g port velocty vs excursion, SPL vs group delay)
- Realtime T/S tweaking - T/S tile allows you to
- Inline EQ editing - Click EQ on the SPL tile, right click to add EQ points and drag around
- Mobile support - Works fine for now - further optimisations incoming soon
- Import/export from WinISD - Export or import .wpr files with full compatibility
- Wiring - Auto generates series/parallel configurations, pick to see amplifier impact when running multiple drivers
- Paste webpage/datasheet to create driver - No more trying to find the right textbox for a T/S parameter
- Large + growing driver DB - ~2000 drivers so far, this is part of another project I run (bits.00aud.io). Aiming to build out a large verified open dataset for other tools to build on
Active development:
- MCP - Allowing agents to connect to your workspace and brainstorm/simulate on your behalf
- Share revamp - Allowing commenting/sharing of files/github projects to better support open source
- Traced datasheets - support for more granular FR/impedance plots. This will form the basis of ZMA/FRD imports and more measured data
- Validation dataset - open source initiative to publish large dumps of WinISD projects and output to cross verify this tool (or other novel simulators in this space!). This will go into a published report accompanying each release so deviations/enhancements can be documented and improved over time. This will include share links to track any potential drift, so your shared designs don't change
- Mobile refinements - swipe to switch graph rather than scroll
Future:
- Directivity simulation
- Embeddable plots to third party sites
- Crossover design (post-measurement support)
- Transmission line + horn support
Once again, massive thanks to the community and users for providing feedback to get it to the point where it is today.
Would love any thoughts/feedback!
Try it here: 00 Simulator - App
Future:
