Project Overview:
This report documents the achievement of extreme acoustic coherence at alevel of 0.0006 ms in a 13.5 m2 domestic environment. The project demonstrates that legacy hardware (30-year-old Technics SE-HD units) combined with modern AMT ribbons and meticulous "ManualGainStaging" can achieve a temporal resolution exceeding that of high-end commercial studios.
Key Performance Metrics (Final Laboratory Setup):
*Phase Alignment Record (L+R vs L): An unprecedented 0.20 mm (0.0006ms) was achieved. With 23 drivers firing simultaneously, the system creates a monolithic point source. The phase error is now smaller than the thickness of a sheet of paper.
*Frequency Range: Full-range reproduction from 12 Hz (infrasonicpressure via Fenton down-firingsub) to 17.5 kHz (operator's biological hearing limit, compensated by a +10dB bias on the AMT ribbons).
*Clock Stability: Utilizing a "Full-Featured" USB-C cable for the measurement chain, clock adjustment drift was stabilized at arecord 2.5 ppm, enabling microsecond-accurate data acquisition.
*The Reference Sweet Spot: Calibrated to exactly 150 cm (distance) /107 cm (height) / 168 cm(offset from left wall).
ENGINEERING CONCLUSIONS:
1.The Human Body as an Acoustic Element:
At a 0.20 mm precision level, the listener’s position becomes acritical part of the crossover. Leaning back into the chair shifts the phase by 0.28 mm, proving the system is sensitive enough to register micro-changes in tor so geometry and furniture reflections.
2.Architecture of Gain Staging (-12dB Paradigm):
The implementatio of a passive RCA attenuator (10.4 kOhm) successfully managed the "hot"CD output. Operating the Behringer processor in the "Green Zone"(-12dB to -6dB) unlocked vital headroom, eliminating high-frequency fatigue (e.g., Rebecca Pidgeon’s sibilance) while preserving the physical "proximity effect" of studio microphones.
3.Selective Signal Hygiene (The AMT Pure Path):
Rejecting passive filtration for the AMT section, while applying it to the Creative units and freeing the Fenda woofers from ground loops, restored "transient speed." Every passive filter in the main path previously acted as a brake, causing impulse smearing.
4.Forensic Audio vs. Room Gain:
The system operates in two distinct modes:
*150 cm (Sweet Spot): Surgical truth, 0.2 mm phase, exposing mix flaws (e.g., the thin, recessed drums in 80s Polish Metal productions).
*+1 Meter Back: Room mode sadd "thump" and mass where the original recording engineer failed.
5.Infrasonic Integrity (12 Hz - 30 Hz):
Running the Fenton sub at 40 Hz (L-Pass) against a 100 Hz Behringer Sub-Outfills the lowest octave without triggering mechanical resonances ("Nothing rattles"). Due to the 0.2 mm phase alignment, 12Hz is experienced as pure atmospheric pressure rather than furniture vibration.
FinalVerdict:
The"Seven-Amping"project proves that in high-fidelity audio, Time (Phase) is the absolute master. By synchronizing 23 drivers within a 0.2 mm window, the room boundaries effectively disappear, leaving an "acoustic X-ray" of the recording. This marks the end of the engineering phase — the system is now a dedicated teleportation device for deep-listening sessions.
This project documents the achievement of surgical, "headphone-like"precision and massive "Wall of Sound" scale in a 3.3m x 4.1m x 2.8m room. The goal was to prove that mechanical time alignment, combined with a meticulous analog/digital hybrid signal path, can rival high-end DSP-corrected systems at a fraction of the cost ~$1000).
Hardware&Seven-Amping Architecture:
*Technics Legacy Stack: SE-HD501 (Factory Bi-Amp for reference signal), SE-HD60(EQ-processed for HD50A monitors), SE-HD50 (Dedicated for AMT Modules).
*Custom DIY AMT Modules: 15W/8 Ohm, sealed pineen closures, 3.9uF MKP crossover (~5.1 kHz) with integrated L-Pad. Grilles removed for zero diffraction.
*Active Support: Fenda TX-60Pro (Towers), Fenton 8” Down-firing Sub(180° Phase), Creative GigaWorks T20 Series II.
*Infrastructure: Triple-layer passive RCA cascade, hybrid OFC wiring (Bandridge 4mm/900 strands + YYTCG 120strands), and dual-end Ferrite chokes on every cable.
*Filters: Custom passive RCA isolation + dual-end Ferrite chokes.
*Measurement Stand: "Custom High-Mass Glass Stabilizer"(Green BottleSolution) providing zero-resonance microphone positioning.
Transparency&Sonic Character (The "Truth" Test):
*Holography: Significant soundstage depth (e.g., piano appearing 30meters behindthe speakers in Yello's "You Better Hide").
*Resolution: Extreme sensitivity to EQ—a mere 0.5dB boost in the 400-800Hz range was immediately audible, balancing "clinical"tracks without losing transient speed.
*Real-World Monitoring: The system does not "beautify." It exposes natural vocal grain (Rebecca Pidgeon) and handles 20dB dynamic jumps (Hans Zimmer) with zero compression or "stress."
*"Headphone Killer": Provides the analytical detail of high-end headphones but with avisceral, physical kick to the chest.
Acoustic Integration:
The system embraces room asymmetry (open door rear-left, large window right). By utilizing the open-door strategy and manual driver offsets, standing waves were minimized, allowing the physical 0,2 mm alignment to dominate the acoustic signature.
FinalVerdict:
