理性派HiFi X5 Speaker Review
Rate this speaker:
    Votes: 53 25.0%
    Votes: 132 62.3%
  • 3. Fine (happy panther
    Votes: 26 12.3%
    Votes: 1 0.5%
This is a review, detailed measurements and listening test of 理性派HiFi X5 speaker. It was kindly purchased by a member in China and drop shipped to me. It costs CH Yuan 2280 (USD $327) for the finish in this sample, and 1980 ($284) without per pair.
The walnut finish is quite nice and I appreciated the rounded corners and overall feel of the unit. Back panel is unusual in what it doesn't show than what it does:
And that is, lack of port. Bookshelf speakers universally have ports to improve bass response and it is interesting to see this speaker do without. Binding posts are hard to see but they are quite beefy/premium.
Speaker is not sold outside of China so I don't have an English name for it. Company designer has a large and positive reputation in China.
Reference axis was that of the tweeter. The baffle is tilted back ever so slightly. I measured it as if this was not the case. Post measurements, I looked at -10 degree measurements and it is quite close to the 0 degree so I stayed with that.
理性派HiFi X5 Speaker Measurements
As usual, we start with our anechoic spinorama measurements
Seems like there is a general attempt to get a flat on-axis response. That however is marred by about four resonant peaks. Near-field response shows the same almost 1 to 1:
Directivity is good resulting in the same wavy response off-axis:
Company recommends desktop/near-field use so our simulated in-room response doesn't quite apply:
Distortion is surprisingly low but with one sharp peak at 86 dBSPL:
Beamwidth is wider than normal which is a good thing in near-field meaning as you move left and right, tonality doesn't change a lot:
Same for directivity:
Vertical directivity is typical of 2-way speakers indicating that you should stay at its tweeter axis:
Impedance is higher than typical 4 ohm which makes it an easier load on the amplifier:
Waterfall is pretty clean other than the few resonances:
Finally, here is the step response:
理性派HiFi X5 Listening Tests
Company promotional video shows the speaker on desk flanking the monitor so I tried it there. But there was too much bass enhancement in my setup so I opted to listen to it in near-field but at the edge of the desk. That improved the boominess but more filtering was necessary:
Paradoxically, it wasn't too bad as is because the extra highs were countering the peak around 700 Hz. I was refining the EQ by stepping through my tracks until I got to the one you see above: Fading Sun from Teje Insugset. I use this track to test sub-bass response which the X5 handled with ease -- much better than many bookshelves. But as soon as some higher pitched impulses arrived, the speaker started to sing by itself! Clearly an internal resonance was triggered causing much elongated notes as if there was another instrument was playing along.
To verify it was not a setup issue, I swapped the X5 for Revel M105. The M105 fell apart on sub-bass, producing quite distorted sound there but did not at all suffer from that resonance. Next I switched the Hypex amp I was using for a Topping La90. It made no difference and the X5 proceeded to yet again clearly sing along. The distortion is quite convincing: if I had not listened to this track hundreds of times on countless speakers, I would have thought it was part of the music!
At this point I terminated the testing as this issue is a showstopper. Shame as the fidelity was quite good and speaker played quite clean and loud prior to this final failing.
As house inspectors say, there are clearly "good bones" in this speaker. I like the approach of not having a port as that can easily color mid-rang with its/cabinet resonances if not carefully designed. In desktop use, you are liable to get bass enhancement anyway so why not go with a sealed enclosure. The bass driver seems capable. The tweeter though has clearly resonances as evidenced by its wavy resonances.
I think the company is close to have a very good and innovative design here. I hope to take this data and refine it. Once there, I would love to re-test it.
As it is, I cannot recommend the 理性派HiFi X5 speaker.
EDIT: please see the teardown of 理性派HiFi X5 here: https://www.audiosciencereview.com/forum/index.php?threads/理性派hifi-x5-speaker-review.42528/post-1506363
  • 理性派Hifi H5 Frequency Response.zip
YSC
Gave it fine as the on axis is not bad on flatness and surprisingly good directivity on the design. Plus it’s price it don’t seems much should be demanded.
Ok I am surprised to see traditional Chinese characters in here too so take my opinion with grain of salt
That shrimp skin is a online selling platform in Taiwan
He’s just asking if they can sell it through that
Ah, I thought he was talking about speaker finish!
Entropy
67°40'17"N 51°19'34"W
Nicely Finished small speakers, seems to be reasonable. Something like the JBL studio 530s do definitely blow them out of the water at this pricepoint, though, although without looking nearly as nice.
Maiky76
French, living in China
Here is my take on the EQ.
Please report your findings, positive or negative!
The following EQs are “anechoic” EQs to get the speaker right before room integration. If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there: https://www.audiosciencereview.com/...helf-speaker-review.11144/page-26#post-800725
The raw data with corrected ER and PIR:
Score no EQ: 3.6
With Sub: 6.6
Spinorama with no EQ:
  • Not horible
  • knock off scanspeak drivers
Directivity:
Better stay at tweeter height or just above
Horizontally, better toe-in the speakers by 10/20deg and have the axis crossing in front of the listening location, might help dosing the upper range.
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
Score EQ LW: 5.5
with sub: 7.9
Score EQ Score: 6.0
with sub: 8.4
Code:
Hifi H5 APO EQ LW 96000Hz
March022023-104657
Preamp: -3.6 dB
Filter 1: ON HPQ Fc 59.42,    0.00,    1.50
Filter 2: ON PK Fc 165.34,    -2.85,    1.07
Filter 3: ON PK Fc 767.34,    -2.98,    2.76
Filter 4: ON PK Fc 4959.36,    -2.54,    2.91
Filter 5: ON PK Fc 9081.60,    -1.49,    3.75
Hifi H5 APO EQ Score 96000Hz
March022023-104657
Preamp: -3.4 dB
Filter 1: ON HPQ Fc 59.18,    0.00,    1.49
Filter 2: ON PK Fc 168.55,    -2.98,    0.94
Filter 3: ON PK Fc 804.50,    -3.14,    1.96
Filter 4: ON PK Fc 4875.67,    -3.59,    2.02
Filter 5: ON PK Fc 9342.88,    -2.61,    1.83
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
Nice improvements
The rest of the plots is attached.
  • Hifi H5 APO EQ Score 96000Hz.txt
  • Hifi H5 APO EQ LW 96000Hz.txt
Mario Sanchez
Doesn't look too bad, all things considered. Throw in some extra filters and it should make a fine desktop setup for a reasonable price, though usability doesn't look great right out of the box, and the tweeter level seems a tad too hot.
The manufacturer did talk about how this model is "made for desktop use" too, so maybe that dip across upper bass is some form of pre-emptive desktop compensation filter baked into the response, still no justification for the funny resonance around the 400Hz mark.
ThomasXia
An active speaker version based on this one with correct DSP integrated could be much more promising I think.
BTW, The designer of the speaker seems to have expressed his displeasure with this measurement indirectly on social media in China. (www.bilibili.com)
讲个业内有意思的八卦。
公司都有测试部门。但是现在越来越多的公司都要再单独花钱找专业的测试公司,原因是公司高层信不过自家测试部门。高管们虽然不懂技术,但是也不傻,这也太明显了。听说尤其是一些做tws耳机的手机公司,基本上都信不过自己人了。这是何苦呢,如果大家都讲点诚信,也没必要这样内耗吧。 当然,这里讲的测试公司是业内的专业公司和顾问,不是面向大众的所谓的测评自媒体,所谓的测评媒体,多半只是单纯的广告公司
Tell an interesting piece of industry gossip.
Even though manufacturing companies have testing departments, more and more have to pay for a professional testing company separately because the company executives have lost trust in their own testing department. Although the executives are unfamiliar with the technology, they can easily find the fishy tricks in their own measurement. I heard that, especially for some smartphone companies having TWS products, they don't trust their own people, which is the origin of the pain. If we all speak a little integrity, there is no need for such internal conflicts. Of course, the test company mentioned here is the industry's professional companies and consultants, not the so-called self-promoting media for the public, the so-called test media, most of them are simply advertising companies.
julian_hughes
Fabulous! I'll have faith in AI and algorithmic translation when it can deal with translating S.E Asian, Korean, Japanese and Chinese idioms into English. Until that point is reached we are better off not assuming we have any clue what the hell is going on.
maxxevv
That should be referring to Shopee.com.tw . A popular online shopping platform in Southeast Asia as well as Taiwan.
" 理性派 " can be intepreted as " objective / rational party/sect " if taken literally.
GXAlan
Are there any evidences which your comment is based on?
I think everyone is curious about the latest AVRs. We haven’t seen an A8A, a Cinema 50, or AVR-X4800H yet, let alone the AV10 which is in customer hands. We have Sony too.
For speakers, JBL 4305P, MoFi Sourcepoint, Klipsch Sevens and Nines, KEF R meta, etc.
For electronics, HiFiRose streamers, the new JBL Classic line, NAD C3050, etc.
