Tommy_Tango
Latest activity Postings About
    • Tommy_Tango
      Tommy_Tango reacted to Roland68's post in the thread SMSL PA400 GaN 500W with Like Like.
      I think that's utter nonsense. This reviewer always thinks the newer or more expensive devices are somehow better, just like magazines...
    • Tommy_Tango
      Tommy_Tango replied to the thread SMSL PA400 GaN 500W.
      Tharbamar discovered the difference between the the pa-x and the pa400, the pa-x has a little better powersupply, otherwise they are...
    • Tommy_Tango
      Tommy_Tango reacted to Roland_606's post in the thread SMSL PA400 GaN 500W with Like Like.
      I have a hypex nc252 stereo power amp that I was using prior to the PA400 and I appreciate the headroom of the mono setup now. My...
    • Tommy_Tango
      Yes i find it the same way, but if i wanna buy two and use them in mono, isn’t it just better getting a class d amp with more power like...
    • Tommy_Tango
      Hey does anyone know how to set the pa400 into stereo power amp mode, the only 3 modes i can find is rca, xlr and mono power amp? Does...
    • Tommy_Tango
      I dont have the possibility of blind testing or instantly switching between amps, I'm a normal person so I report what I hear in...
    • Tommy_Tango
      OK, so here is my verdict comparing the PA400 to the Fosi V3 Mono and the Parasound Halo A21. The speakers I used are Ø Audio horn...
  • Loading…
  • Loading…
