You should upgrade or use an
alternative browser.
T
That’s what I’ve been doing. It works, but is slightly inconvenient. I forgot once and was away from the phone for about 10 minutes and...
T
As far as I know, there is only one power mode. Power On/Standby. And that’s according to the manual. It doesn’t charge while in use...
T
I just bought one and I’m pretty disappointed. It works fine, but it goes into standby mode if it gets no signal for 3 minutes, then...
T
It boils down to whether you want to drain your phone battery or not. If you are on the go and don't have access to power, then...
Loading…
Loading…
