You should upgrade or use an
alternative browser.
T
T-4n14 replied to the thread
Topping DX5 II.
No need for this language here. Time to catch up with the civilized world.
T
I cannot recommend SMSL SU-1. Mine broke after a year of using it.
SMSL SU-1 was replaced by Fosi Audio Q6, very similar in sound and...
T
If you want something with similar performance and price point, you could go with a Fosi Audio Q6. That's what I did when I received a...
T
Yes indeed. The volume goes down. Thank you for advice. I searched online the voltage converter but did not have much luck. There is a...
T
My SMSL SU-1 has a static or white noise. The music is barely audible. The SU-1 worked well for a few months. A USB to Toslink/Coaxial...
Loading…
Loading…
