You should upgrade or use an
alternative browser.
O
Mate this is super helpful.. I have done exactly this and I'm glad to see we have the same results.
My reason behind not using the 18s...
O
If you've already chosen the drivers this greatly simplifies the process because all you have to do is choose the dimensions of your box...
O
If you are building a speaker I always recommend speaker design software. (WinISD is free.) It will help you to optimize a sealed or...
O
I've spent a lot of time looking at subwoofer drivers and simming designs recently. If you're willing to make a large enough cabinet...
O
I'm not set on sealed design as much as I'm set on what's best for the specific drivers I'm looking to use. As mentioned the ultimax 12...
O
As I mentioned before the driver I'm considering is the Dayton ultimax 12 and the recommended sealed boxes are small and ideal for my...
O
OP, what are your requirements for box size, frequency response, and budget? Are you set on a sealed design?
O
https://www.audiosciencereview.com/forum/index.php?threads/multeq-x-software-for-windows-pc-anyone-tried-it.31547/ have a read mate
O
It's an upgrade when you have more control of the system and also you can use a better mic
O
No I mean the MULTEQ X SOFTWARE it's a £200 upgrade and it's on windows
Also this is my sub amps specs .
It's a hypex fa502
Rated...
O
Yea thanks mate and hopefully it will be good. I have so much control over everything with the level of EQ from the denon and the hypex...
O
OK makes sense..... too bad you can't figure out how to put 2 of your JBL subs in the room.... that I am sure would perform well :)...
O
From the way my room measures I will be putting one left and right of me a quarter of the way into the room on each side so from running...
O
This is the sort of answer I was hoping for... My JBL is my dream subwoofer but due to the room I need to change to 2 subs and the...
O
If you like the JBL punch, the closest sealed 12" I’ve heard that keeps that same energy is the Dayton UM12-22. You’ll lose a bit of...
Loading…
Loading…
