M
Latest activity Postings About
    • M
      marco_iol reacted to magor34's post in the thread Topping DX5 II with Like Like.
      Any regular 3-pin XLR-cable should be good.
    • M
      marco_iol replied to the thread Topping DX5 II.
      DX5 II version V1.93 firmware update 6. What's updated *Fixed: Several other known issues Let me say a minor update.
    • M
      marco_iol reacted to Berwhale's post in the thread Topping DX5 II with Like Like.
      PEACE is a front end for EqualizerAPO that makes it easier to use. https://sourceforge.net/projects/peace-equalizer-apo-extension/
    • M
      Because with WASAPI exclusive in Musicbee W11 does not resemple anything.
    • M
      With Musicbee, which I use for FLAC files and CD, I have set WASAPI exclusive in the preferences/player and I have installed the VST...
    • M
      If you want the sample rate on the DAC to change to match the source, then you need to set your player to use an audio driver with an...
    • M
      The matter is that the sample rate and bit depth are fixed in W11. It is possible to change them in the speaker properties, but I don't...
    • M
      marco_iol reacted to ohezeba's post in the thread Topping DX5 II with Like Like.
      One way is to select Equalizer APO ParametricEQ at the top, download the .txt file, and then use Import Filters in Topping Tune.
    • M
      PEQ = Changing bits whether its implemented by software on Windows or using a DSP capability of a DAC. You are just moving the bit...
    • M
      Starting from the configurations available in https://www.autoeq.app/, do you know how or can you post a procedure I can follow up in...
    • M
      Hi I had some issues with the last firmware 1.78 - a lot of stutter/jitter listening to the CD (the CD reader is connected to the PC)...
  • Loading…
  • Loading…
