You should upgrade or use an
alternative browser.
M
I just finished my speakers and they sound very good to my ear. I built them using passive radiators (16g added mass) and the bass is...
M
I glued two frames together. Then the double ones into the next pairs. Four layers connected gave two blocks. This allowed me to connect...
M
Out of curiosity: How did you get everything glued up neatly in line? Did you build a jig for that, too?
M
Yes. They were scrap from a friend's carpentry shop. So large that they fit the dimensions of the housing. Interestingly, they were...
M
Nice approach, and thanks for the detailed reply! Did you use 30mm plywood for the build?
M
Hi Jarbar,
Stellar woodwork! How did you cut the material out of those frames?
Loading…
Loading…
