You should upgrade or use an
alternative browser.
C
I'm "warming up" to the A7's sound. I was thinking it was "thin" but it may be accurate. The A7 allows me to unplug the ports on my...
C
Thanks for explaining the switch- the "doc" was not helpful.
Simultaneous back/forth:
..........--> AVR Pre Int --> low into AVR Amp...
C
The "Bypass Vol" switch is actually a "Bypass | Volume Control" switch. It probably won't make a difference in practice, but to make...
C
Such Yamaha AVR typically has 28-29 dB gain so with the A7 volume control on bypass, gain set to high, the two should be level matched...
C
No. The A7 will still have much less distortion than an AVR regardless of volume bypass or RCA gain settings.
C
New owner 3e A7 (stereo) w/48V. I have a very nice switch so I am evaluating the A7 "side-by-side" my AVR (Yamaha RX-A4A). The A7 is...
Loading…
Loading…
