A
Latest activity Postings About
    • A
      alin_im replied to the thread Calibration Microphone.
      Hi all, coming back with some results from the calibration files of the Dayton Mic. Using MAB methodology, I have tried the 90 degrees...
    • A
      Understood, sounds logical. I will try what MAB said as well and maybe the guys at Spectrum Labs will send me some calibration files...
    • A
      thank you for confirmation!
    • A
      hi thank you for this! did you apply an offset to the values or what was your methodology of creating the 90?
    • A
      alin_im reacted to Blumlein 88's post in the thread Calibration Microphone with Like Like.
      Attached is the 90 degree cal file for the Dayton. You can compare it to a measurement you do seeing how close it is by duplicating 0...
    • A
      alin_im reacted to MAB's post in the thread Calibration Microphone with Like Like.
      It looks correct:
    • A
      thank you much appreciated!
    • A
      This would work and you'll know for sure. I'll adjust the OPs provided file and upload it later. Not at home right now.
    • A
      funny enough, I was thinking to do the same thing, but I thought it might be a little too junkie to do it and I was not sure how...
    • A
      thank you very much! attached is the calibration file provided by Dayton. how would you do it?
    • A
      I already have one from a local distributor, not Cross spectrum unfortunately...
    • A
      Hi all, coming back to the newbie land... The Dayton emm-6 has 1 calibration file, i suspect that is done at 0 degrees orientation...
    • A
      So many opinions :D I made the decision to chat with audio dealer and they will send both a UMIK1 and a Dayton. Will test both and...
    • A
      I will have a play with UMIK when it comes and see if this satisfies my requirements. As you said, I need for simple room measurements...
    • A
      Thank you for the info. I have seen a lot of people are choosing the UMIK-1. TBH my initial thought was not going with a USB...
  • Loading…
  • Loading…
