39_eneX
Latest activity Postings About
    • 39_eneX
      39_eneX reacted to staticV3's post in the thread IFI IEMatch+ questions with Like Like.
      If you don't want to buy an external headphone Amp, or modify the Yamaha's internal Amp, then all you can do is switch to higher...
    • 39_eneX
      39_eneX replied to the thread IFI IEMatch+ questions.
      The Schiit Magni is not a bad option, plugging that amp to the Stereo Out of the Yamaha should fix everything I'll take this approach
    • 39_eneX
      39_eneX reacted to john61ct's post in the thread IFI IEMatch+ questions with Like Like.
      see Schiit "Imp" if only FYI designed so low-current Output Transformerless (OTL) tube amplifiers can drive difficult, low-impedance...
    • 39_eneX
      UPDATE 2: It clips with the Yamaha at listening levels, I just had luck with some specific songs. It's fine with the Steinberg but it...
    • 39_eneX
      UPDATE: The iFi IEMatch+ just came in the mail! Let's remember about the two main issues I had before using it: - Steinberg IXO 22...
    • 39_eneX
      Oh, I didn't know about the iFi Ear Buddy! I wonder if the IEMatch will clip that early though... Thank you for the link!
    • 39_eneX
      https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-ifi-ear-buddy-and-iematch.4707
    • 39_eneX
      I found this "DUNU Original Earphone Impedance Plug Jack/Adapter Converter" which seems to be a good alternative...
    • 39_eneX
      39_eneX reacted to RandomEar's post in the thread IFI IEMatch+ questions with Like Like.
      I would think that the required 40 Ohms is meant to limit the current the headphone amp has to provide. Lower Ohms headphone - > higher...
    • 39_eneX
      Mind linking the review? I couldn't find it myself
    • 39_eneX
      Thank you so much for the very detailed response! With this, all of the questions I made were answered. Essentially (and if I'm not...
    • 39_eneX
      I think what iFi mean is that potentiometers lose balance as you approach minimum volume, and so by attenuating the signal downstream...
    • 39_eneX
      I actually had to look this one up, because it puzzled me. The answer is: This is a voltage divider. It has one resistor in series with...
    • 39_eneX
      https://www.audioreviews.org/ifi-iematch-must-have/ Just a quick mention to this article I found. It's very detailed and makes some...
    • 39_eneX
      That makes so much more sense. At the end of the day, the added 16 ohm impedance solves both the hiss and the analog imbalance, reaching...
  • Loading…
  • Loading…
