Lars Roon Bridge/Server Build on a Budget Thread
Sal1950
The Chicago Crusher
Central Fl
D
Deleted member 65
Guest
Not too be too much of a shill, but you might want to check out the little thing I wrote on building a Roon bridge on the cheap, if you ever want to build a 2nd one:
http://audiosciencereview.com/forum...endpoint-raspbery-pi-hifiberry-digi-pro.1116/
Ripped my new Roon Bridge apart. Contemplating which spouse strategy to use (yet to be defined). Followed your advice and built (built is maybe too strong word) a RaspBerry Pi3. Works brilliantly, attached a DLink USB WiFi dongle I had lying around.
Installed in new mediaroom, hardly visible.
D
Deleted member 65
Guest
About to restart my build of Silent MediaPC, this time not so much on a budget using latest technology just released from Intel.
Bought new Asus Z370 Coffee Lake motherboard today, Intel i7/8700 CPU's not yet available here. Settled for Asus since I've built a number of PC's based on their mb's & I need onboard Wi-Fi which isn't available from that many suppliers.
https://www.asus.com/se/Motherboards/ROG-STRIX-Z370-E-GAMING/
Sal1950
The Chicago Crusher
Central Fl
Great, be an interesting follow. Curious as to see how it's going to be cooled.
D
Deleted member 65
Guest
I'll be using same HD-Plex chassis as the failed one above. Failure solely caused by me thinking I could reuse an old AMD based mb & CPU.
Note - All previous pictures are unavailable due to the Ad Clad Photobucket imposing charges to share photos with other websites, about to change to Flickr/Imgur.
D
Deleted member 65
Guest
Asus Z370 motherboard installed together with Samsung 960EVO 250GB M.2 hidden under M.2 cooler which is a nice touch by Asus.
Coffee Lake i7 8700 CPU's estimated to arrive late October at the earliest in Sweden.
Worth noting: Only Coffee Lake CPU's work in a Z370 mb. Physically socket is identical to the 1151, however pin assignment differ.
SAM_1286 by Lars Strömberg, on Flickr
script>
Yeh Intel broke CPU pin out compatibility. This is why when my machine died, I bought a temporary i5+motherboard to get Coffee Lake when it is fully released. Reports show that it is becoming available in US sporadically depending on model.
D
Deleted member 65
Guest
Or wait for Z390 due next year ... Wait, Intel hijacking the 390 from IBM
D
Deleted member 65
Guest
Need assistance from some of our computer savvy members.
Connected new PC to old HD TV (Philips 47" 9664 with HDMI 1.3a connectors) in MediaRoom, TV capable of 1080p video i.e 1920*1080.
Received error code from TV "Videoformat not supported", tried different video settings on PC, from 1024*768 without success.
What could this be?
Note, this TV worked fine in main listening room with different older PC (Z170) and 1080p resolution. Main room now has a Philips OLED TV connected to the Z170 Roon Core PC, works great.
Soniclife
What could this be?
Did you try different refresh rates?
D
Deleted member 65
Guest
Works now, installed semi old Philips 32" TV I had intended to move into summer house. Seems something was wrong with old TV.
