I think so, or rather down to 200-300 Hz. While there may be some benefit below 200-300 Hz in some rooms with certain placements, the directivity is gradually lost and swamped by room modes, dependent on the room (size and materials).Could it be that the main subjective improvement of the beolabs or the Kiis doesn't lie in the directionality of the very deep bass, but rather that they're directional down to the midbass? Say to 120-150-200 hz? To be directional that far down is nevertheless vastly better than almost all other commercial loudspeakers.
I've measured a horn that has a certain controlled (cd) directvity down to approximately 90 Hz with a few placements and compared it to a direct woofer. While I generally see a flatter response with the horn it's by no means independent of the room and modes. The lower you get, the less benefit there is. If cd really worked great for low frequencies, we should be able to move the speaker and sitting position around and not see much change. If that was the case with Kii and Beolab 90, you have to wonder why in room measurements aren't showed as it would be very convincing and great marketing.
