Dutch & Dutch 8C Kii THREE killer?
Purité Audio
Industry Insider
Barrowmaster
London
Arriving next week, some say they are better than the superb Kii THREE ,Dutch&Dutch's new 8C monitors.
watchnerd
Seattle Area, USA
These might be the best FR, phase, and dispersion plots I've ever seen:
This further confirms my axiom that there is no point in buying anything except active monitors with DSP optimization built-in.
This the beginning of the end for passive speakers*.
*(Okay, they'll stick around forever, too, like OTL tube amps and horns. But they're post-peak.)
watchnerd
Seattle Area, USA
Both Kii and Dutch & Dutch are tiny.
How long before one of the big boys (Focal, KEF, Dynaudio, B&W, Harman) adopts the same approach and drops the price in half?
watchnerd
Seattle Area, USA
M A X L I N E A R S P L @ 1 M : 1 0 6 D B C O N T I N U O U S F R OM 3 5 H Z U P WA R D S *
L F : 5 0 0 W
M F : 2 5 0 W
H F : 2 5 0 W
That's 1000W per speaker, total.
Sal1950
The Chicago Crusher
Central Fl
How's that possible? They're not even sprayers, and horn loaded to boot? ;)
Sal1950
The Chicago Crusher
Central Fl
You mean wave guided...
OK, if you want to get technical (this is ASR after all) ;)
They're not even sprayers, and wave guided to boot!
Bet the drivers are even highly efficient.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
They do look good there designer has heard the Kii's next to the 8C's and prefer the 8C's but he would wouldn't he!
Kii THREE and Dutch& Dutch together!
Notice the expensive high quality stands that the 8C are on!
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Cheaper than the Kii's around £8k per pair inc vat and 1000w of raw power!
watchnerd
Seattle Area, USA
Actually, looking at the power and max SPL, I don't think the drivers are particularly efficient, although they seem high excursion.
Thomas savage
The Watchman
uk, taunton
Time to move to balanced with the big boys.
Been there done that, I found no obvious advantage to balanced in my domestic hifi setup.. At the time preferred my preamp and amps (both single ended) over the krell gear I was using ( all balanced)
But yes, I'd likely sell everything if I went active. I'd rather 12" bass woofers though.
watchnerd
Seattle Area, USA
I'm skeptical of the birch plywood....
Plywood isn't usually considered superior to MDF from a technical POV.
