Jakob1863
Btw, you avoided carefully to touch the crucial points (i.e. what measurements reflect the "transparency" of an amplifer); i did not ask for a specific amplifier that you would consider to be transparent, although personally i´d consider the mentioned amplifiers as very good, means wrt measured performance and sound quality as well.So answer my question, where are the good controlled listening test results showing amplifiers sound different? Once again you offer nothing of substance.
I don´t know much about the swedish tests oivavoi mentioned - is there some documentation available - but i´ve said before, that we started with doing controlled listening tests back in the 1980s, after having read some publications from Dan Shanefield and others, who brought the idea to the audio field, and those tests included capacitors, amplifiers, preamplifiers and cd-players as well. Funny that the 1982 article about the different sound of amplifiers (probably due to clipping) was among those articles, but i didn´t remember until amirm wrote about it.
I totally agree with you, that such results aren´t very surprising when using typical electrostatic speakers, given their low efficiency (full range often between 76 dB and 82 dB) and their complex impedance.
But even with normal passive loudspeakers (including two way mini monitors and three way monitors) it was always possible to confirm the sighted impression in controlled blind listening tests. Which doesn´t mean that all amplifiers were vastly different.
But the interesting point was, that beside the usual specs (given by manufacturers) more sophisticated with complex load simulation, additional IMD/TIM measurements did not reflect those perceptable differences.
PS. looking at well documented listening tests for all kind of "debateable effects" there are some to find, which offer evidence that the effects were detectable. Usually there is a correlation between training, experience and accomodation to test conditions and rejection of the null hypothesis. Otoh, as perfect tests are unlikely, there are nearly always some questionable points left.
